What should I do if the hub/dock's Lightning audio port does not work?
  • Here are some troubleshooting tips to help you locate and resolve the problem.
    For laptops:
    ● Make sure you set the audio output to the correct mode on your laptop:
    ① macOS: Open System Preference > Sound > Output > External headphone.
    ② Windows: Left-click the sound icon in the taskbar > Select the device in the drop-down menu > Choose the connected headset.
    ● Try this device with a different laptop to see if the issue persists.
    For Lightning audio devices:
    ● Confirm whether the audio device can work normally without the hub/dock.
    ● Try a different Lightning audio device.
    For hubs/docks:
    ● Try using a different hub/dock with a Lightning audio port to see if the audio device can work well.
