In the world of fast-charging technology, two terms often come up: GaN chargers and PD chargers. While both aim to deliver efficient power to your devices, they serve different purposes and use distinct technologies. Understanding their differences can help more people make an informed choice.
What is a PD Charger?
PD (Power Delivery) is a fast-charging protocol developed by the USB Implementers Forum (USB-IF). It allows compatible devices (like smartphones, laptops, and tablets) to negotiate optimal charging speeds dynamically.
Key Features of PD Chargers:
- Uses USB-C as the standard port for high-power delivery.
- Supports variable power outputs (e.g., 18W, 30W, 65W, 100W).
- Charges devices faster than traditional USB-A chargers.
- Widely adopted by Apple, Samsung, Google, and other major brands.
However, PD is just a charging standard—it doesn’t define the charger’s internal components.
What is a GaN Charger?
GaN (Gallium Nitride) is a semiconductor material used in charger manufacturing. Compared to traditional silicon-based chargers, the advantages of GaN Chargers:
- Smaller size – GaN conducts electricity more efficiently, reducing heat and allowing for compact designs.
- Higher efficiency – Less energy is wasted as heat, improving performance.
- Faster charging – Supports high-wattage charging (up to 100W or more) without overheating.
- Multi-device compatibility – Many GaN chargers include PD support, making them versatile for phones, laptops, and tablets.
Unlike PD, GaN refers to the charger’s hardware, not the charging protocol.
Key Differences Between GaN and PD Chargers
| Feature | GaN Charger | PD Charger |
| Technology | Uses Gallium Nitride for efficiency | A fast-charging protocol (not hardware) |
| Size | Compact and lightweight | Can be bulkier (unless it's GaN-based) |
| Efficiency | Higher efficiency, less heat | Depends on the charger's components |
| Compatibility | Often includes PD support | Requires a PD-compatible device |
| Power Output | Can support 100W+ charging | Typically maxes at 100W (USB-C PD standard) |
Which One Should You Choose?
- If you want a compact, high-speed charger → A GaN + PD charger is the best choice.
- If you only need fast charging for a phone/tablet → A standard PD charger (without GaN) may suffice.
- For laptops and high-power devices → A GaN PD charger (65W-100W+) is ideal.
MOKiN 140W 4-Port USB-C GaN Foldable Compact Wall Charger$49.99
The USB C Charger Block with 3 USB-C ports and 1 USB-A port, connect a single USB C device to get maximum output 140W, charge your MacBook Pro 16'' to 56% in 30 minutes,and compatible with all smartphones and tablets. |
| Learn More | Buy Now |
For tech enthusiasts and frequent travelers, investing in a GaN PD charger is a smart move—delivering fast charging in a pocket-friendly size.
