Troubleshooting Common Issues with 100W GaN Charger 4 Ports
  • 100W GaN chargers with 4 ports are becoming increasingly popular due to their compact size, high-power output, and ability to charge multiple devices simultaneously. However, like any piece of tech, they can sometimes run into issues.
    MOKiN 100W Foldable and Compact USB C GaN Charger (4 Ports)
    1. Devices Not Charging
    Issue: Your devices are not charging when connected to the 100W GaN charger.
    Possible Causes and Solutions:
    ① Check Cable Connections: Ensure that all cables are securely connected. Sometimes, a loose cable can cause charging issues.
    ② Cable Quality: Use high-quality cables that support the power requirements of your devices. Low-quality cables may not deliver sufficient power.
    ③ Port Compatibility: Ensure that you’re using the correct port for your device. Some ports may have different power outputs, and using the wrong one can result in insufficient charging.
    ④ Power Delivery (PD): Verify that your device supports Power Delivery and that the charger is providing the correct power output. Some devices may require specific power profiles to charge properly.
    ⑤ Reset the Charger: Disconnect the charger from the power source and all devices, then reconnect everything. Sometimes, a simple reset can resolve charging issues.
    2. Overheating
    Issue: The charger is getting excessively hot during use.
    ① Ventilation: Ensure that the charger has proper ventilation and is not covered or obstructed. Overheating can occur if the charger cannot dissipate heat effectively.
    ② Power Load: Check the total power load on the charger. If you’re charging multiple high-power devices simultaneously, the charger may overheat. Try reducing the number of devices or using lower-power devices.
    ③ Environmental Factors: Avoid using the charger in high-temperature environments. Excessive ambient heat can contribute to overheating.
    ④ Faulty Unit: If the charger continues to overheat despite these measures, it may be a faulty unit.
    3. Intermittent Charging
    Issue: The charger works intermittently, with devices charging and then stopping.
    ① Cable Issues: A faulty or damaged cable can cause intermittent charging. Try using a different cable to see if the issue persists.
    ② Port Issues: Check the ports on the charger for any debris or damage. Clean the ports carefully if necessary.
    ③ Power Source: Ensure that the charger is properly connected to a stable power source. An unstable power supply can cause intermittent charging.
    ④ Device Compatibility: Some devices may not be fully compatible with the charger, leading to intermittent charging. Check the manufacturer’s specifications for compatibility information.
    4. Slow Charging
    Issue: Devices are charging slower than expected.
    ① Port Selection: Ensure that you’re using the correct port for your device. Some ports may have lower power outputs, which can result in slower charging.
    ② Cable Quality: Use high-quality cables that support the power requirements of your devices. Low-quality cables can limit charging speed.
    ③ Power Load: If you’re charging multiple devices simultaneously, the total power output may be divided among the devices, resulting in slower charging. Try charging fewer devices at once.
    ④ Device Settings: Some devices have settings that control charging speed. Check your device’s settings to ensure that it’s set to charge at the maximum speed.
    5. No Power Output
    Issue: The charger is not providing any power to connected devices.
    ① Power Source: Ensure that the charger is properly connected to a working power source. Try using a different outlet or power strip.
    ② Reset the Charger: Disconnect the charger from the power source and all devices, then reconnect everything. Sometimes, a simple reset can resolve power output issues.
    ③ Faulty Unit: If the charger still does not provide any power, it may be a faulty unit. Contact the manufacturer for support.
    6. Device Compatibility Issues
    Issue: Certain devices are not charging or are not recognized by the charger.
    ① Power Profiles: Some devices require specific power profiles to charge properly. Ensure that the charger supports the necessary power profiles for your devices.
    ② Cable Compatibility: Use cables that are compatible with your devices and support the required power delivery.
    ③ Device Settings: Check your device’s settings to ensure that it’s set to charge when connected to the charger.
    By following the troubleshooting steps outlined above, you should be able to resolve most common problems. If you’re still experiencing issues, it may be worth reaching out to the manufacturer’s support team for further assistance.
