Hi,
I recently purchased the Mokin TB4 docking
| UPC | 728619603022 |
. I worked fine with my windows laptop. I have two minitor, one 24inch and one 49inch monitor both connect to the dock through DP port. I was trying to use it with my macbook pro with m2 pro chipset. but it always connect 49inch monitor and not detect the 24inch monitor. I tried different cable and connections, it seems if I disconnect the 49inch monitor, then the system can detect the 24inch monitor, then I plug the 49inch monitor back, the macbook can detect both monitor correctly.
it is annoying that I have to physically unplug a dp cable everytime I connect to the dock. can you check if there is anything to resolve it?
thanks,
Samuel
