When your network cut out, you can check from the below steps:
① Test if there is a problem when only connecting the network cable.
② Cross-test. Try to connect the docking station to another device that has an ethernet port.
③ If the device is OK, check if the Type-C port is loose or if the product works flat on the desktop.
④ Please try again after updating the network drive.
