DDC control possible for both HDMI ports 8 in 1 MacBook hub and and 9 in 1 MacBook hubs?
  • Looking for hub that supports DDC control across both HDMI ports and Ethernet, multiple USB ports.
    DDC Control across both HDMI ports does work on MOUC0408 (8 in 1), but it does not have Ethernet port.
    Will the 9-in-1 product have abiilty to control DDC for both HDMI port? (brightness, contrast, input source, etc.)
    Thanks,
  • Hi Kurt Hammond
    Thank you for posting!
    May I know whether you connect the DDC control with the hub?Or do you connect the DDC control with your laptop,then plug the hub into your laptop?
    And also since there are many products that are 9-in-1, could you please kindly tell us the details of the product you want,or you can advise us of the link of the product you are interested.
    Thanks a lot!
    Looking forward to your reply.
    Best regards,
    MOKiN Support
