Mokin Docking station does not work
  • Hi,
    I have mokin docking station. I connect two monitors, and a webcam to my laptop via the station. It used to work perfectly, but all of a sudden it works only for charging. It does not connect monitors and webcam to my laptop. I need help regarding this, and solve the proble.
  • Hi @Arif Mirzayev,
    To solve your problem quickly, please provide the information and try the way below.
    1)Please provide the product model and laptop model;
    2)Please provide the product order date;
    3)Is the usage environment changed?
    4)Please find other mobile phones, tablets or computers that support video output to test whether the hub works normally.
    Looking forward to your reply.
    Best regards
  • @Mokin Global
    1. Laptop model is HP Elitebook 840, and product model is MOUC0412.
    2. I ordered it last month, and have been using since then.
    3. There is no change in the environment.
    4. I have checked with another laptop, but it worked for that one. So, it seems there is something laptop-specific.
  • @Mokin Global is more information needed or?
  • @Arif Mirzayev
    Thank you for the information you provided;
    If the product can be used normally on another computer after testing, please check whether the monitor is recognized in the settings and consider upgrading the program and graphics card driver. For the camera, consider uninstalling and reinstalling the driver.
  • Good morning!
    I purchased a MOKIN MODK0705 Docking Station, serial number H52AA050149, which doesn't work with the Beelink EQR6 6900HX micro PC, AMD Ryzen 9 6900hx, Windows 11 Pro, Version 24H2. I tested it on a DELL INSPIRON P132F laptop and it worked perfectly.
    Is the MOKIN MODK0705 Docking Station compatible with the Beelink EQR6 6900HX PC?
    Do I need to install any drivers?
    Please provide instructions on how to use the product.
    Important addition: I currently use the DELL D6000 Docking Station on the same PC (Beelink EQR6 6900HX) without any difficulty in connecting two monitors and other peripherals. My intention is to replace the DELL Docking Station with the MOKIN one.
    Thank you.
  • Hi @LUIZ ARAUJO,
    The docking station isn't compatible with your laptop Beelink EQR6 6900HX PC;
    Here are two products can support your laptop, just download the driver:
    MODK1102: https://mokinglobal.com/products/displaylink-docking-station
    MODK1501: https://mokinglobal.com/products/15-in-1-displaylink-docking-station-dual-monitor
  • tem alum video mostrantrando com instalar?
  • @Django Ferreira
    Olá,
    Como a maioria dos hubs são plug and play, pedimos que nos informe o modelo específico do seu produto, o modelo do seu computador e descreva o problema que você está enfrentando.
