Refer to the following troubleshooting tips that may help locate and resolve the problem:
① Make sure you’re using the right kind of charger for your device.
To charge a device fast, both the connected charger and device need to support the same charging technology. For example, to fast charge a Samsung Galaxy S8, a Qualcomm Quick Charge charger is needed; to superfast charge a Samsung Galaxy S21, a PPS (Programmable Power Supply) charger is required.
② Distinguish between the total wattage and the maximum wattage.
When using a multi-port charger, take a closer look at the specs to differentiate between the total wattage and the maximum wattage that a single port can support. For example, the 60W dual port has a 15W USB-A port and a 45W USB-C Port.
③ Try another cable and a different outlet.
