when my laptop is connected to the hub the laptop will take 3 minutes to show the bootup logo, when there is not hub it boot up within 30 sec. Connecting a 3.x thumb drive 512GB when extracting the data it will slow down the laptop to the point the entire screen will not move. anybody had seen this issue ?
Hello @george yeh
Sorry this happened. To better solve your problem,could you please provide the following information:
❶Could you provide your detailed laptop model?
Such as: HP Pavilion x360 2-in-1
❷Could you provide the product model and SN number?
Looking forward to your reply!
Hi,
I also have the problem that my HP laptop does not seem to boot if my Mokin 9-in-1 usb-c hub (MOUC0304) is connected to it (I have never tried to wait for 3 minutes to see if it eventually boots).
My laptop is an HP Elitebook 855 G7.
My laptop is powered through a separate power supply (not through the hub). On the hub I have 3 USB-A devices & a DP display.
My current work-around is to disconnect the hub from my laptop whenever I want to boot up the laptop, but that is not very practical...
Please help...
@Piet Van den Abeele
Hi,
Please try to open the BIOS settings and start the hard drive.
Having any problems, please contact us in time.
Best regards,
MOKiN Support
It sounds like the USB-C hub might be interfering with your laptop's boot process, which is a common issue with some docking stations and hubs. Here are a few things you could try to resolve the problem:
BIOS/UEFI Update: Check if your HP EliteBook 855 G7 has any BIOS or UEFI firmware updates available. Sometimes manufacturers release updates to resolve boot conflicts with external devices.Disable Boot from USB: Go into your BIOS settings and disable the "Boot from USB" option. This could prevent your laptop from trying to boot from the devices connected through the hub.Driver Update: Ensure that you have the latest drivers installed for both the USB-C hub and your laptop. This could resolve compatibility issues during boot.
What does the blinking light green and blue mean?
